Revision as of 15:48, 30 October 2011 by Rich (Talk | contribs)
Seiko 6R15/6R20
Same as the 2824-2 but also supports day of week. Copies include the Sellita SW220 and junk out of China. Watches with this movement are usually in the $450-$900 range. You can find this movement in Tissot, Hamiltion, Mido, and a handful of other brands (including fake Rolexes).
