Crank Radios
Currently there are a number of wind-up crank radios available from numerous vendors. These radios are usually marketed as "emergency" radios rather than alternative powered radios. These radios are popular in hurricane/tornado prone areas because they can be stored away for long periods without the user having to worry about keeping fresh batteries in it. Most of these radios include NOAA weather reception which tends to be more reliable/informative during weather related disasters.
Here are photos of the Sangean MMR-77 (after I replaced the incandescent light with a LED):
