Extension Arms and Antenna
The collapsible antenna by itself will work as a quarter-wave on 10m (pictured below) and should also tune up ok on 12m. It will work as a quarter-wave on 15m if you add the two aluminum extension arms.
$799 FT857D w/YSK857 $95 TCXO-9 $82 MH-59A8J DTMF mic (also needed for direct freq entry) $120 W4RT2.3khz ssb filter $169 Z-11pro2 $14 IBM PA-1121-0711 16V 7.5A Notebook Power Supply Adapter (ebay) $2 bridge rectifier KBPC5010 (ebay) $144 (8) 16ah 40160s lifepo4 $24/ea (bmsbattery.com or manzanitamicro.com) $3 (8) 40160S battery holders 0.40/ea $4 (8) 40160S bus bar connectors 0.50/ea $80 battery shipping $97 (2) 30A Battery Management PCB http://www.batteryspace.com/pcbprotectioncircuitmodulefor4cells128vlifepo4batterypackat30alimited.aspx $11 USB to serial converter http://www.usbgear.com/computer_cable_details.cfm?sku=USBG-RS232-F12&cats=199&catid=482%2C199%2C601%2C461 $8 3/8X24 Thread Mirror Mount: Wilson 901104 $5 (20') Belden 8219 (RG58A/U) $3 (4) Amphenol 83-185-RFX (UG-175 reducer) $20 (4) Amphenol 83-822 (PL259) $10 shipping (theantennafarm.com) $79 Jansport Driver 8 TN89-008 UPC 757969203361 Wheeled Backpack (buy.com) $6 dual-band (2/440) whip with 3/8x24 mount (hamstick EDBW-1, Opek DB-1, or Workman DB-1) $4 (2) CONXPARTSA Kenwood KW2000 (Parts A) $3 (6 feet) Red & Black DC wire 12 GA $9 shipping (k1cra.com) $11 (3') LMR-600 (showmecables.com) $1 (4) 1/4"-20 nuts (7/16" head) $1 (4) 1/4"-20 x 3/4" bolts $2 (8) 1/4"-20 wingnuts $9 (10') 4" drainpipe (we need one 7 3/4" piece) $4 (2) 4" drainpipe cap (home depot) $20 (5) littelfuse FHA30 12AWG inline fuse holder $3 (1) 5-pack of ATO 7.5 fuse (drillspot.com) $3 4' 14 gauge cable (for short part of radio power connector) (.62/ft) $1 4' 18 gauge cable (for battery sense +/- to pcb, low power wire on power cable) (.31/ft) $6 (1) 1/4" (22-18) Ring Terminal 50pcs $4 (1) 1/4" (16-14) Ring Terminal 50pcs $6 (1) 1/4" (12-10) Ring Terminal 50pcs $10 shipping (parts-express.com) (1) DB9F mouser 156-1309 0.80 (4) BC546A mouser 512-BC546A 0.10 (2) 5.6k 1/4w mouser 588-OD562JE carbon comp 5% 0.42/ea (3) 10k 1/4w mouser 588-OD103JE carbon comp 5% 0.42/ea (1) 3.5mm 3-pin plug (cw) (2 wires used) mouser 568-NYS231BG 1.69 (for cw jack) (1) 8-pin mini-din (cat) (4 wires used) mouser 171-2608 1.49 (1) 6-pin mini-din (data) (4 wires used) mouser 171-2606 1.36 (2) 600ohm 1:1 transformer mouser 42TL016-RC 1.66 (2) 51 ohm 1/4w mouser 588-OD510JE 0.42 (1) 1uf cap mouser 5989-100V1.0-F 0.71 (1) .0047uf cap mouser 140-50P5-472K-RC 50v ceramic disc 0.12 (1) 100 ohm 1/4w mouser 588-OD101JE 0.42 carbon comp 5% (1) 1k 1/4w mouser 588-OD102JE 0.42 (1) board mouser 854-PR1593K $4.10 2.6 x 2.6 (1) box mouser 546-1593KBK $2.88 (box is 2.6 x 2.6 x 1.1) (2) 2.2k resistor 1/2w carbon comp 5% mouser 588-OF222JE (1/4w mouser 588-OD222JE 0.42 not avail) (4) PL259 right angle Amphenol 083-1AP UG-646/U Mouser 523-83-1AP $14.70/ea (1) 2.5x5.5mm right angle plug (24AWG) power plug for tuner mouser 171-3216-EX $1.04/ea (2) ferrites - mouser 875-LFB187102-000 3.03/ea 3/4" OD .400" ID 1.125" long (3 turns RG58 = 1000 ohm impedance @ 1-5mhz) (2) mouser 526-WH22-00-100 100' 22awg copper 7-strand hookup wire black nteinc.com $19 (use p/n 03-100 for orange) insulation OD 0.060" (2) 3.5mm stereo jacks 502-35RAPC3BV4 2.73 $112 total $12 shipping (mouser.com) $8 (1) 14-pack 3/8 ring terminal 16-14AWG (JT&T 2011H - amazon.com) $18 (2) 8ft 3.5mm stereo cables (mediabridge - amazon.com) $3 21/64 (.3281") drill bit for 3/8-24 threads (amazon.com) $28 3' Aluminum 6061-T6 Seamless Round Tubing, WW-T 700/6, 1/2" OD, 1/4" ID, 1/8" Wall, 36" Length (amazon.com) $65 Opteka CFM300 68" 5 Section 8x Carbon Fiber Monopod (amazon.com) $209 (1) PowerFilm F15-1200 20W solar panel 10.5 x 6.5 x 0.6 1 lb (amazon.com) $11 (4) EZ-Hook XM (digi-key 461-1004-ND) $2 Akro-Mils plastic dividers (Akro-Mils 40150 wasserstrom.com) $1 (8) 3/8-24 Jam Nuts 18-8 Stainless Steel $1 (2) 3/8-24 Hex Nut 18-8 Stainless Steel $10 (5) 3/8-24 x 1-1/8 Hex Coupling Nut 18-8 Stainless Steel $1 (10) 3/8" USS Flat Washer 316 Stainless Steel $7 shipping (fastener-warehouse.com) $7 (5') 1/4" schedule 80 PVC pipe (usplastic.com) $14 (2) coleman 827E140T colthesline reel (coleman.com) $40 Voile Tourlight Probe (this is our 8 foot antenna rod) $2 (2) 6" tent stakes $2 (1) 4-pack of 10" bungee cords $10 tax/shipping (rei.com) $12 (1) F-125-K Toroid Core 1.25" 250-300 permeability low loss ferrite 1-30 mhz (theaudioguru.com) $11 (1) 1/4 lb Wire, 16ga (0.05") enameled (we need 4 feet for toroid) (allspectrum.com or jameco.com) $20 (1) 79-87283 DonJoy COMFORTFORM WRIST support-Small right (expressorthopedics.com - warning, it takes them a month to ship it) $8 Cables To Go 52030 - 6ft DB9 M/F All Lines Extension Cable Black (nextwarehouse.com) $12 (1) 85058K8 25-pack nylon edge trim .065 gap width /16 opening, 15/64 height, 12 3/4 long $21 (1) 8871K71 80' spool .064" (14ga) tin coated copper wire (spool says Arcor 14AWG) $2 (1) 91187A202 1.5" 5/16-18 RHT stainless stud (or you can order a 10-pack for $4.55 with part number 95412A587) $10 (2) 95412A657 5-pack of 1.25" 3/8-24 RHT stainless stud $9 tax/shipping (mcmaster.com) ========== $2516 approximate cost $? (1) stickyback velcro (attach tuner to radio mount) $? (1) velcro wire ties (attach coax to antenna mast) $? (1) 3/8-24 tap $? (1) 5/16-18 tap $? (1) Jaycar UB5 clear jiffy box (for balun) 3x2x1" $? (4) 30A (12-14AWG) red/black powerpole connector (1 for radio, 2 for batteries, 1 for AC/DC power supply)
