Radio RF Output: Minimum of 20W, preferable to have optional 50W+ available if needed Radio Frequency coverage: HF, 6 meters, 2 meters, and 70cm Radio Modes: FM/SSB/CW/packet Radio receive current: preferably less than 700mA Tuner: 10-500ohm minimum, preferable little to no idle current Battery: sufficient to handle a weekend without recharging Power: Battery, AC, or solar Antenna: Vertical or dipole with optional voltage balun PC: Small netbook capable of digital modes Size: Everything fits within a pack suitable for airplane carry-on (21x14x10"). All items: Weight as minimal as possible !
Excessive cost for this project. Otherwise a great radio !
Tempting, and would pair nicely with LDG Z-817 tuner. Only problem is I want 20W+. This could be accomplished with a Tokyo High Power HL-45B
HF/50 MHz: 5 watts = 4.0-4.7 amps 10 watts = 5.3-6.4 amps 25 watts = 7.3-9.2 amps 50 watts = 10.6-12.9 amps
both the 857 and 897 will automatically limit the radio to 20W when running on battery power (by grounding the brown wire on the power connector). Spec says voltage is 12.4-15.2, manual says 11.73-15.87.
For honorable mention we have the long-discontinued Kenwood AT-130 which is a very small 80-10m(+WARC) manual tuner (6 x 2.4 x 6.3 inches, 3.5 lbs.). For field ops I prefer a small autotuner. Yaesu makes the FC-30 ($170, 17-150 ohms, 3.1 x 1.8 x 10.2 in, 2.2 lbs) however its 17-150 ohm tuning range is quite narrow compared to the LDG product line.
$200 LDG YT-100 (latching relays) for 857/897 100w = 1.5lbs 4-800 ohm 7 x 7 x 2 $200 LDG AT-897+(latching relays) for 857/897 100w = 2.0lbs 6-800 ohm 11.5 x 3.25 x 1.5 $160 Z100+ ? 125w 6-800 ohm 5.5 x 5.5 x 1.5 1 lb w/o batts $170 Z11pro2 6-1000 ohm 7.7 x 5.0 x 1.5 1.5lb w/o batts
I ended up going with the Z11pro2 as it can autotune based on RF sense which keeps the CAT and ACC ports free. This is good because we need both ports for our data interface. Another bonus of RF sense tuning is it makes the radio PC-ALE capable provided the antenna is tunable on whatever ALE frequencies are to be used.
Paired with each battery pack is a circuit which protects from overcharge/overdischarge/overcurrent. It also keeps the batteries balanced while charging. After a long search for a suitable lightweight container I found the 4-battery pack fits perfectly into a "Huggies" baby wipe plastic box.
PowerFilm F15-1200 20W (10.5 x 6.5 x 0.6" 1 lb ) Nice compact and light panel but a little pricey at $10/watt. I would have gone with their 30W panel but it was even more overpriced.
Fortunately I found an 8.5' collapsible aluminum pole made for measuring snowpacks and after some tinkering it worked like a charm. Paired with a couple of 18" aluminum extender rods and a large tapped coil it turned out to be a usable antenna. Obviously running a huge coil with a short antenna is about as worthless as a short helical so its important to remember to use as much whip or longwire as you can if you are less than 1/4 wave.
For a horizontal option I built a tapped voltage balun which connects to two spools of wire. These wire spools can also be used as a counterpoise for vertical configurations.
For VHF/UHF I have a 17" dual-band antenna or another option for VHF only is putting one of the 18" aluminum rods onto the 1" antenna mount. 6 meters can be done with the 17" antenna on top of both 18" rods.
I looked at dozens of packs before settling on the Jansport Driver 8. Most other packs were either oversized and/or too heavy. My reasoning for a 21x14x10" size limit is so you can carry this on a commercial airplane if you are traveling. You certainly wouldn't want to check this as luggage as it would probably get destroyed by handling or stolen. Two main things I liked about the Driver 8 are the wheels and the telescoping arm. The telescoping arm is wonderful because it is very sturdy aluminum which allows you to securely attach an antenna to it. This is great for manpack operations if you want the antenna up while you are walking around with the pack on your back. It also works great for fixed operations as the pack itself can be used as an antenna base. The wheels not only give you back a break where smooth surfaces are available, they also give you the ability to easily lay down the pack when assembling a long antenna. Its like having a mini fold over tower.
