Kenwood TK-6110
Kenwood TK-6110 / TK6110 mods for 6 meters and 10 meters
The TK-6110-K2 covers 35-50mhz
KPG-59D to program.
Freq area in codeplug file: $1840-$1A3F
As an added bonus, it will also work on 10 meters too !
Ch 1: TX/RX 42.60 mhz
Ch 2: TX/RX 35.10 mhz
Ch 7: TX/RX 50.00 mhz
Ch 11: TX/RX 54.00 mhz
Ch 12: TX/RX 29.50 mhz
The following procedure will re-tune the frontend varactor to handle 50-54mhz. The important setting here is setting "sensitivity" to 255 at 54mhz. This prevents a binary rollover from the CPU to the DAC which feeds the varactors, otherwise the DAC will suddenly shift the frontend passband down to around 30mhz when the radio is above about 51mhz. Also, setting it to "134" for 29.50mhz will make the radio work on the 10m band ! (The binary rollover situation is the reason why you can't simply back out the transformer slugs).
Ch 1: 134
Ch 2: 134
Ch 7: 213
Ch 11: 255
Ch 12: 134
Now program the radio. With the stock KPG-59D you can put in freqs 10mhz less then hex-edit the file to move the freqs from 40mhz to 50mhz. The freq area in the file is $1840-$1A3F. An easier way is to use my modified version of KPG59D which I call KPG59X. This allows you to directly enter in 6-meter & 10-meter frequencies. KPG59X is available here: http://www.interceptradio.com/files/misc/kpg59x.exe
Here is how to connect both a 10-meter and 6-meter antenna without a duplexer: http://www.repeater-builder.com/antenna/diplex-low-band-antenna.pdf
