Yaesu VX-7R
Alignment:
Hold down MONI/F + INTERNET + 0 then press the power button. V/M to change Press MONI/F to select power & deviation levels for low-end and high-end of the band Pres F HM/RV to save changes and exit
Default values:
50 52 54 144 145 148 220 222 225 430 435 440
