Mount Rainier National Park
Revision as of 07:51, 25 July 2012 by Forest3433 (Talk | contribs)
The following Frequencies are used in the park, common users are NPS, USFS, WSP, 169.7250 Main Park 163.7125 Common 168.6125 Common 163.0650 Common 169.9000 USFS F1 156.1350 OSCCR 159.0900 Buckley Fire, Medic 35 sometimes closes ALS unit (AMR unit with AMR Paramedic and Buckley Fire EMT on board)
Dispatch Park Comm Center located at Tahoma Woods Enumclaw Enumclaw Police Dispatch used in evening and some holidays for "LE units" (Law Enforcment) Unit 100 Park Superintent Most 7** Units are Park LE Forest 55 USFS LE
Radio Term's
Channels and Repeaters  Direct (no repeater)  Gobbler’s Knob Repeater (Westside)  Packwood Repeater (South, Southeast)  Shriner Peak Repeater (Stevens Canyon, Hwy 123/410)  Crystal Mountain Repeater (Sunrise to north Park boundary)  Mount Fremont Repeater (North backcountry)  Tolmie Peak Repeater (Carbon, Mowich, Wilkeson)  Local (no repeater)  Helicopter Ops/Portable Repeater  Flagging
