It is currently Wed May 23, 2018 9:50 pm
Post new topic Reply to topic  [ 18 posts ]  Go to page 1, 2  Next
 Post subject: Anchorage
PostPosted: Mon Aug 01, 2016 4:25 am
851.0500 is listed as trunked under WPWL668, but I'm catching it conventional with a DPL of 032. Not enough to guess yet.
Perge, Scelus, Mihi Diem Perficias.
 Post subject: Re: Anchorage
PostPosted: Thu Aug 04, 2016 12:54 am
851.0500 (D032)- Sounds like AIA Maintenance, interspersed with trunked traffic. Yuck.
Also, the FedEx hub system is running smoothly.
Control file for 'FedEx Anchorage Airport'
; (12 frequencies, 2 talkgroups, 0 patches, 7 radios)
;;[Settings]
System Type = 4
SysID #1 = 2407h
; 800 MHz Standard Bandplan
Bandplan Range #1 = 851.0125 25.0 0
Bandplan Range #2 = 866.0000 25.0 720
Bandplan Range #3 = 867.0000 25.0 815
Bandplan Range #4 = 868.9750 25.0 958
Bandplan Range #5 = 867.4250 25.0 961
Bandplan Range #6 = 0.0000 0.0 0
Bandplan Range #7 = 0.0000 0.0 0
Input Bandplan Range #1 = 0.0000 0.0 0
Input Bandplan Range #2 = 0.0000 0.0 0
Input Bandplan Range #3 = 0.0000 0.0 0
;;[System Info]
; system number, system name / fleetmap / active banks
2407, "FedEx Anchorage Airport"
; SS1 [130CF]: Affiliate on PwrUp; Connect tone: 128.57 Hz;
; No dispatch timeout; Interconnect timeout: 15 min.
;;[Channels]
; channels: bandplan channel number, physical channel number, frequency, time limit, BSI, control channel, comms count
154, 0, 854.8625, 0, 0, 0, 3
194, 0, 855.8625, 0, 0, 0, 2
213, 0, 856.3375, 0, 0, 0, 2
233, 0, 856.8375, 0, 0, 0, 1
253, 0, 857.3375, 0, 0, 0, 3
273, 0, 857.8375, 0, 0, 0, 2
293, 0, 858.3375, 0, 0, 0, 1
314, 0, 858.8625, 0, 0, 0, 2
333, 0, 859.3375, 0, 0, 0, 1
354, 0, 859.8625, 0, 0, 2, 0 ; CC (current)
373, 0, 860.3375, 0, 0, 0, 1
394, 0, 860.8625, 0, 0, 0, 1
;;[TrunkTracker Talkgroups]
; talkgroups: number, name, priority, color, options, banks, date/time last heard, number of comms ; TT ID
176, "", 50, 14, , U, 1-AUG-2016 4:19, 18
528, "", 50, 14, , U, 1-AUG-2016 4:15, 1
;;[Decimal Radio ID's]
; radio ID's: number, name, favourite.alert.priority, color, date/time last seen, <talkgroup/number of comms>; number
; TG 176 radios:
837, "", 0, 10, 1-AUG-2016 4:16, <176, 2> ; 345
910, "", 0, 10, 1-AUG-2016 4:18, <176, 2> ; 38E
915, "", 0, 10, 1-AUG-2016 4:18, <176, 6> ; 393
924, "", 0, 10, 1-AUG-2016 4:19, <176, 1> ; 39C
934, "", 0, 10, 1-AUG-2016 4:16, <176, 1> ; 3A6
995, "", 0, 10, 1-AUG-2016 4:17, <176, 1> ; 3E3
1038, "", 0, 10, 1-AUG-2016 4:18, <176, 1> ; 40E
;;[EOF]
PostPosted: Sun Nov 27, 2016 4:24 pm
; TRUNK88 Rev. 4.88J Copyright 1998-2012 W. A. Porrett (wap@ica.net / slicerwizard@gmail.com); Control file for 'FedEx Anchorage Airport'
; (12 frequencies, 3 talkgroups, 0 patches, 10 radios)
;;[System Info]
;;[Channels]
154, 0, 854.8625, 0, 0, 0, 4
233, 0, 856.8375, 0, 0, 0, 2
273, 0, 857.8375, 0, 0, 2, 2 ; CC (current)
314, 0, 858.8625, 0, 0, 0, 3
354, 0, 859.8625, 0, 0, 1, 0 ; CC
528, "", 50, 14, , U, 25-NOV-2016 3:07, 2
816, "", 50, 14, , U, 25-NOV-2016 3:01, 2
; TG 176 radios:
; TG 528 radios:
832, "", 0, 10, 25-NOV-2016 3:07, <528, 1> ; 340
; TG 816 radios:
800, "", 0, 10, 25-NOV-2016 2:57, <816, 1> ; 320
1053, "", 0, 10, 25-NOV-2016 3:01, <816, 1> ; 41D
PostPosted: Fri Dec 09, 2016 10:48 pm
From TSAIA yesterday:
851.050 (D032)- Airport maintenance
938.9625- UPS trunked system; SysID 6233, CT 83.72. I'll Trunk88 it next time I'm around.
The previously-noted FedEx trunked system produced:
272- Unknown
304- Unknown
432- Unknown
496- Only someone with an open mic that REALLY doesn't like their job.
560- Maintenance traffic
592- Unknown
816- Unknown
PostPosted: Sun Dec 18, 2016 9:13 pm
463.275 (TRBO; cc-1, slot 1, tgid 1) water trucks around TSAIA
464.7625 (103.5)- Alaska Air at TSAIA
PostPosted: Thu Jan 05, 2017 5:54 pm
851.350 (D023)- TSAIA unknown
851.600 (D043)- TSAIA plows/sanders
PostPosted: Sat Jan 14, 2017 10:23 am
451.9375 (186.2)- More Alaska Airlines at TSAIA....Conversation was too vague to determine use yet.
460.650 (162.2)- Delta Airlines at TSAIA, both ramp ops and gate agents.
460.825 (D606)- Unknown at TSAIA- possibly Korean Air.
461.6625 (156.7)- Swissport at TSAIA.
462.500 (110.9)- Cathay Pacific at TSAIA.
464.375 (100.0)- LSG Sky Chefs, TSAIA
PostPosted: Wed Jan 18, 2017 7:23 pm
460.875 (123.0)- PenAir at TSAIA.
151.670 (Slot 1, CC 1, TGID 100)- International Aviation Services at TSAIA.
PostPosted: Wed Feb 01, 2017 8:14 pm
461.6125 and 462.0375 belong to ArctiCom as a DMR trunked system, but the only traffic I found after discovering it was on these 2 freqs.
TGIDs:
70- Shuttles between the airport and Marriott, US Customs, and CBF (?).
80- Aircraft fueling, unknown if it was at TSAIA or Merrill Field. A Pilatus needed fueling, and someone was asking about a Caravan arrival time.
110- Cabs?
130- Not enough to go on
150- A hotel?
155- Hotel shuttle. Goes to Hampton Inn, airport, Hilton Garden Inn.
160- 2 guys chatting while plowing snow.
170- Cabs?
240- Hotel shuttle
PostPosted: Fri May 05, 2017 10:08 pm
851.350 (D023)- TSAIA Police/Fire
851.100 (D054)- TSAIA Emergency Channel...only radio checks on the hour (probably a good thing)
851.600 (D043)- TSAIA Airfield Maintenance
PostPosted: Sun Jul 02, 2017 1:00 pm
851.100 (D054)- Has either changed from the Emergency Channel or I misinterpreted it's use. Seems to be the unarmed security in the parking garages, drives and the checkpoint exits.
PostPosted: Thu Sep 07, 2017 8:28 pm
Channel is called "Purcell".
See: https://www.nmsusa.com/services/security/
PostPosted: Thu Sep 07, 2017 8:30 pm
167.6375 ($167)- Only encrypted
170.750 ($293)- US Courthouse
172.450 ($455)- Kenai Natl Wildlife Refuge
165.3375 ($293)- Encrypted
172.350 (100.0)- Too DX
461.025 (141.3)- UAA; unk use
46701- ALMR LE Region F Tac-1
856.2875 (103.5)- Providence ANC; Security (r)
855.5125 (100.0)- Providence ANC; Engineering (r)
49902- ALMR TSAIA Tac-2 Electricians working
PostPosted: Thu Sep 07, 2017 8:34 pm
TGIDs:
110- Cabs?
150- A hotel?
170- Cabs?
240- Hotel shuttle
250 (Arcticom DMR)- Hotel shuttle
70 (Arcticom DMR)- BAC Transportation
80 (arcticom DMR)- Signature Flight Service at TSAIA
110 (Arcticom DMR)- Only a radio check and a few dead keys
130 (Arcticcom DMR)- Fuel transload facility. Channel-1
150 (Arcticcom DMR)- Hotel ops. Shuttles, housekeepers
155 (Arcticcom DMR)- Hotel shuttle to Hampton Inn, AIA, HGI, Homewood Suites. Same brand, so I suspect in-house and not contract.
160 (Arcticcom DMR)- unk
180 (Arcticcom DMR)- Related to 130?
240 (Arcticcom DMR)- unk
250 (Arcticcom DMR)- Hotel shuttle
PostPosted: Sun Oct 01, 2017 9:12 pm
461.025 (141.3)- UAA Athletics (Simplex)
409.000 (cc1, TG 100)- Unk security, VA PD? (input 413.825)
410.600 (cc1, TG 200)- Elevator mechanics
