It is currently Wed Jun 20, 2018 9:34 am
PostPosted: Sat Apr 02, 2016 11:39 pm
In case anyone is looking to get into ADS-B monitoring there's a great deal thru Amazon currently. Here are the two parts needed.
The first is a custom RTL-SDR (R820T2 chipset + 20db amp) and a 1090 Mhz filter which will be required (especially if you're using an external antenna.)
I've also linked the antenna I use below. I'm using 50ft of LMR-400 coax. (This is the minimum grade coax or you'll probably lose too much signal.) Obviously you'll want to get this antenna up as high as possible with a clear view of the sky.
FlightAware Pro Stick:
http://www.amazon.com/FlightAware-Pro-S ... B01D1ZAP3C
ADS-B Filter:
http://www.amazon.com/ADS-B-1090MHz-Ban ... B010GBQXK8
ADS-B Antenna:
http://dpdproductions.com/page_vhf_air.html#adsbout
PostPosted: Sun Apr 03, 2016 4:25 pm
This one comes up "unavailable, don't know when we will get more"
PostPosted: Sun Apr 03, 2016 4:29 pm
It has been doing that off and on... just keep checking...
PostPosted: Tue Apr 05, 2016 4:29 pm
Just received my stick and it's working quite well... probably about a 25% improvement overall... my range has extended by about 50 miles which is impressive considering our topology around here. My frames went from ~3000 to over ~5000 per minute.
Definitely worth picking up!
Here's a plot from tonight -- after running about 7 hours:
The 170 mile distance is a personal record for me at this location... previously it was 146 miles out.
PostPosted: Sun Feb 12, 2017 12:57 am
Nick -- have you tried 'whatever it takes' (some program whose name I've forgotten) that allows one to pick up whatever mode military jets transmit so they can be 'seen' in flight? I know there's a whole interest group about that on the Net but forget what it's called. I'm curious because of the C-17 and P3 flights that come into Grant County airport in Moses Lake. Plus I see A-6s from time to time. When the A6s want low-level VFR flights, they do a comm check in to Seattle at 255.40. "seattle center, he's apache-2, a flight of two a6s, entering VR-123 at point bravo at 1823Z at 425 knots, exiting at point papa at 1932Z, over"
Nothing like camping at say, Chiwawa River valley north of Lake Wenatchee, and have a flight of A-6s barreling down the valley at perhaps 200 feet AGL.
PostPosted: Sun Feb 12, 2017 3:18 am
Yes, that's what this thread is about. :)
With the appropriate pieces you can set up your own ADS-S monitoring station (manually operated) or buy a Raspberry Pi 3 and use Flightaware to monitor your air traffic in a fully automated operation. FA filters out the military traffic but your *local* station can receive anything/everything that is using ADS-B.
So I see the P3C's out of Whidbey NAS and plenty of C17s and C-130s out of McChord.
