It is currently Wed Aug 15, 2018 12:19 pm
PostPosted: Fri Aug 03, 2018 1:00 am
RR is actually useful, heh.
Been running it for over a year....
It takes some setup, but having a phase 2 'scanner' for the cost of an SDR... love it.
There's also people putting it on Raspberry Pi 3.... Making it portable.
Install Ubuntu
Open terminal window
Code:
cd ~
git clone https://github.com/boatbod/op25
cd  op25
./install.sh
Then you'll need to set up text files for your systems.... defining system freq and NAC
Here's SS911 as test...
Code:
"Sysname"   "Control Channel List"   "Offset"   "NAC"   "Modulation"   "TGID Tags File"   "Whitelist"   "Blacklist"   "Center Frequency"
"SS911 Site 1"   "774.68125, 774.43125, 773.93125"   "0"   "0x1E1"   "C4FM"   "ss911t.tsv"   ""   "40108,40119,40113,40204,30204,40209,40210,40217,40246"
"SS911 Site 2"   "774.48125, 773.98125, 770.60625, 770.35625"   "0"   "0X1E2"   "CQPSK"   "ss911t.tsv"   ""   "40108,40119,40113,40204,30204,40209,40210,40217,40246"
"SS911 Site 3"   "773.73125"   "0"   "0X1E3"   "CQPSK"   "ss911t.tsv"   ""   "40108,40119,40113,40204,30204,40209,40210,40217,40246"
"SS911 Site 4"   "774.70625, 773.20625, 774.20625"   "0"   "0X1E4"   "CQPSK"   "ss911t.tsv"   ""   "40108,40119,40113,40204,30204,40209,40210,40217,40246"
"SS911 Site 5"   "773.48125,772.93125"   "0"   "0X1E5"   "CQPSK"   "ss911t.tsv"   ""
Tab delineated file.
Then run a lengthy command
Code:
cd /op25/op25/gr-op25_repeater/apps/
./rx.py --args -rtl=0 -N LNA:46 -f 772.13125e6 -S 2048000 -V -q 0 -T psrs.tsv -2 -U
and you're set!
There are other options for using a web interface as well...
You do not have the required permissions to view the files attached to this post.
PostPosted: Tue Aug 07, 2018 8:38 am
Could you make a short video of it decoding an IWN VHF site? Whichever site is strongest for you... just curious as to what it looks like. I have an extra laptop laying around so I may give OP25 a shot.
PostPosted: Tue Aug 07, 2018 11:32 am
It might be awhile. But sure...
