System ID : 00F System Name : Nellis AFB WACN : 58544 Tower Number (Decimal): 1-1 Tower Number (Hex) : T0101 Tower Description : Control Capabilities : Data,Voice,Registration Flavor : Phase 1 Call Sign(s) : Timestamp : Thu Feb 1 13:25:22 2018
-Tables #Format: Table ID,Base Freq,Spacing,Input Offset,Assumed/Confirmed,BandWidth,Slots 00,403.00000,0.01250,9.00000,"Confirmed",0.01250,1
-Frequencies #Format: Channel,Usage,Frequency(/Slot),Input Channel,Input Frequency(/Slot),Input Explicit(1/0),Hit Count "00-0280","avd",406.50000,"00-0280",415.50000,0,9 "00-0303","c",406.78750,"00-0303",415.78750,0,0 "00-0335","avd",407.18750,"00-0335",416.18750,0,8 "00-0344","avd",407.30000,"00-0344",416.30000,0,10 "00-0360","avd",407.50000,"00-0360",416.50000,0,11 "00-0389","avd",407.86250,"00-0389",416.86250,0,8 "00-0412","avd",408.15000,"00-0412",417.15000,0,9 "00-0477","avd",408.96250,"00-0477",417.96250,0,9 "00-0489","avd",409.11250,"00-0489",418.11250,0,10 "00-0525","avd",409.56250,"00-0525",409.56250,1,10 "00-0537","avd",409.71250,"00-0537",409.71250,1,10 "00-0612","av",410.65000,"00-0612",410.65000,1,12
-Neighbors #Format: TowerID,TowerIDHex,System ID,Channel,Frequency,Tower Name 1010,"T0A0A",00f,"00-0553",409.91250,"" 1414,"T0E0E",00f,"00-0383",407.78750,""
System ID : 00F System Name : Nellis AFB WACN : 58544 Tower Number (Decimal): 14-14 Tower Number (Hex) : T0E0E Tower Description : Control Capabilities : Data,Voice,Registration Flavor : Phase 1 Call Sign(s) : Timestamp : Thu Feb 1 13:19:02 2018
-Frequencies #Format: Channel,Usage,Frequency(/Slot),Input Channel,Input Frequency(/Slot),Input Explicit(1/0),Hit Count "00-0348","av",407.35000,"00-0348",416.35000,0,3 "00-0383","c",407.78750,"00-0383",416.78750,0,0 "00-0415","av",408.18750,"00-0415",808.60000,1,3 "00-0490","av",409.12500,"00-0490",418.12500,0,1 "00-0524","av",409.55000,"00-0524",418.55000,0,2
-Neighbors #Format: TowerID,TowerIDHex,System ID,Channel,Frequency,Tower Name 101,"T0101",00f,"00-0303",406.78750,""
System ID : 00F System Name : Nellis AFB WACN : 58544 Tower Number (Decimal): 27-27 Tower Number (Hex) : T1B1B Tower Description : Control Capabilities : Data,Voice,Registration,Authentication Flavor : Phase 2 Call Sign(s) : Timestamp : Fri Feb 2 13:50:22 2018
-Tables #Format: Table ID,Base Freq,Spacing,Input Offset,Assumed/Confirmed,BandWidth,Slots 00,403.00000,0.01250,0.00000,"Confirmed",0.01250,1 08,403.00000,0.01250,0.00000,"Confirmed",0.01250,2
-Frequencies #Format: Channel,Usage,Frequency(/Slot),Input Channel,Input Frequency(/Slot),Input Explicit(1/0),Hit Count "00-0319","a",406.98750,"00-0001",403.01250,1,0 "00-0349","a",407.36250,"00-0001",403.01250,1,0 "00-0397","avd",407.96250,"00-0001",403.01250,1,18 "00-0429","c",408.36250,"00-1149",417.36250,1,0 "00-0461","avd",408.76250,"00-0001",403.01250,1,18
_________________ President-in-Exile, Seattle Area Radio Communications And Scanner Traffic Intercept Crew (SARCASTIC) Don't feel bad if you can't use your STD100/200; there are still people using Digital Frequency Search!Bunnery definition for the under-fives
