Two ships in NOLA (among many others) for Fleet Week:
System ID : AD4
System Name : USS Kearsarge (LHD-3) $AD1
WACN : 00000
Tower Number (Decimal): 1-1
Tower Number (Hex) : T0101
Tower Description : 001 $AD1
Control Capabilities : Voice,Registration
Flavor : Phase 1
Call Sign(s) :
Timestamp : Sat May 30 10:12:25 2026
-Tables
#Format: Table ID,Base Freq,Spacing,Input Offset,Assumed/Confirmed,BandWidth,Slots
00,380.00000,0.02500,0.90000,"Assumed",0.01250,1
-Frequencies
#Format: Channel,Usage,Frequency(/Slot),Input Channel,Input Frequency(/Slot),Input Explicit(1/0),Hit Count
"00-1125","v",408.12500,"00-1125",409.02500,0,0
"00-1148","c",408.70000,"00-1492",417.30000,1,0
Also noted was 407.075 but Pro96Com was having fits with this system being in site trunking.
TG-1 only enc
TG-2 operations: Officer of the Deck, Safety, Tour Guides, etc.
USS Farragut (DDG-99) has an EDACS Hydra system on board. I did not dick around with it but noted the control channel on 397.3500 showing a site of 5.
One of the other vessels, I suspect the USCGC Mohawk, though the Eagle could be considered, was using 410.375 (67.0) for operations...mostly dealing with the massive crowds coming on board for tours.
Interesting to see the Kearsarge upgraded from
USS Kearsarge LHD-3, Sys 740E S-001 CT 128.57
And that the Farragut moved from USS Farragut DDG-99, Trunked System Sys C22A to EDACs
and 410.3750 67.0 is the Barque Eagle, they moved away from the old 450/455 Media Channels
