It is currently Thu Mar 28, 2024 4:56 pm
 Post subject: NXDN is coming!
PostPosted: Mon Feb 05, 2018 2:22 am
IG WQHI238
BNSF Railway Co.
[COMMON CARRIER RAILROAD]
[Associated call signs: WPSF971]
Control Point 1 - 4515 Kansas Ave, Kansas City KS 913-551-4639
(link)
02/02/2018 License Modified
(transaction log)
1 - BROADWAYMP1782.9WIU, BNSF LS37 MP1782.9 - BROADWAY WIU, Everett (SNOHOMISH) WA [Structure: Mast] (map)
[Antenna 1 - HTT: 8.2m, Polarization: Vertical, Beamwidth: 360.0°, Gain: 2.5dBi, Azimuth: 30.0°, HAAT: -34.0m]
160.71 FB Ant: 1 35p 50e Units: 1 11K2F1D 4K00F1D (NXDN)
2 - W. Scenic WIU, BNSF LS37 MP 1721.2 - W. Scenic WIU, Skykomish (KING) WA [Structure: Monopole] (map)
[Antenna 1 - HTT: 12.8m, Polarization: Vertical, Beamwidth: 360.0°, Gain: 2.5dBi, Azimuth: 10.0°, HAAT: -570.0m]
3 - E. Scenic WIU, BNSF LS37 MP 1708.3 - E. Scenic WIU, Skykomish (KING) WA [Structure: Monopole] (map)
[Antenna 1 - HTT: 13.7m, Polarization: Vertical, Beamwidth: 360.0°, Gain: 2.5dBi, Azimuth: 300.0°, HAAT: -534.0m]
4 - Cascade Tunnel WIU, BNSF LS37 MP 1700.4 - Cascade Tunnel WIU, Levenworth (CHELAN) WA [Structure: Pole] (map)
[Antenna 1 - HTT: 14.0m, Polarization: Vertical, Beamwidth: 360.0°, Gain: 2.5dBi, Azimuth: 340.0°, HAAT: -425.0m]
160.71 FB Ant: 1 35p 55e Units: 1 11K2F1D 4K00F1D (NXDN)
5 - CP1780 WIU, BNSF LS37 MP1780.0 - CP1780 WIU, EVERETT (SNOHOMISH) WA [Structure: Monopole] (map)
[Antenna 1 - HTT: 10.1m, Polarization: Vertical, Beamwidth: 34.0°, Gain: 5.0dBi, Azimuth: 90.0°, HAAT: -37.0m]
160.71 FB Ant: 1 35p 100e Units: 1 11K2F1D 4K00F1D (NXDN)
 Post subject: Re: NXDN is coming!
PostPosted: Mon Feb 05, 2018 2:25 am
Ah NVM, this just means the ARES data will be going out over NXDN. No voice on this frequency...
PostPosted: Sun Apr 01, 2018 6:30 pm
BNSF New Westminster Sub has an interesting set up . Analog road ch 161.1 is being simulcast with 160.4 NXDN .
PostPosted: Mon Apr 16, 2018 11:57 am
IG WNHI483
BNSF Railway Co.
Control Point 1 - 4515 KANSAS AVE, KANSAS CITY KS 913-551-4615
(link)
04/09/2018 License Modified
(transaction log)
1 - 44 S HANFORD ST, SEATTLE (KING) WA [Structure: Building] (map)
[Antenna 1 - HTT: 10.0m, Polarization: Vertical, Beamwidth: 360.0°, Gain: 3.0dBi, Azimuth: 360.0°, HAAT: -24.0m]
160.47 FB Ant: 1 45p 75e Units: 1 11K2F3E 4K00F1E (NXDN)
160.83 FB Ant: 1 45p 75e Units: 1 11K2F3E 4K00F1E (NXDN)
160.92 FB Ant: 1 45p 75e Units: 1 11K2F3E 4K00F1E (NXDN)
161.01 FB Ant: 1 45p 75e Units: 1 11K2F3E 4K00F1E (NXDN)
161.04 FB Ant: 1 45p 75e Units: 1 11K2F3E 4K00F1E (NXDN)
161.1 FB Ant: 1 45p 75e Units: 1 11K2F3E 4K00F1E (NXDN)
161.16 FB Ant: 1 45p 75e Units: 1 11K2F3E 4K00F1E (NXDN)
161.22 FB Ant: 1 45p 75e Units: 1 11K2F3E 4K00F1E (NXDN)
161.55 FB Ant: 1 45p 75e Units: 1 11K2F3E 4K00F1E (NXDN)
2 - 51 S MASSACHUSETTS, SEATTLE (KING) WA [Structure: Building] (map)
[Antenna 1 - HTT: 6.0m, Polarization: Vertical, Beamwidth: 360.0°, Gain: 3.0dBi, Azimuth: 360.0°, HAAT: -24.0m]
161.55 FB Ant: 1 45p 90e Units: 1 11K2F3E 4K00F1E (NXDN)
3 - 1807 W EMERSON PL, SEATTLE (KING) WA [Structure: Building] (map)
[Antenna 1 - HTT: 6.0m, Polarization: Vertical, Beamwidth: 360.0°, Gain: 3.0dBi, Azimuth: 360.0°, HAAT: -14.0m]
160.32 FB Ant: 1 45p 75e Units: 1 11K2F3E 4K00F1E (NXDN)
161.37 FB Ant: 1 45p 75e Units: 1 11K2F3E 4K00F1E (NXDN)
PostPosted: Mon Jul 23, 2018 8:56 pm
Still trying to figure out the reason for the 160.4 NXDN & 161.1 analog simulcast . Switching and yard crews are still on 160.575 analog . PD is contracted out to CNPD and they are not using NXDN . Could be for interchange with CP I guess CP are running a NXDN trunk on the Vancouver waterfront and in their Port Coquitlam-Pitt Meadows yards .
PostPosted: Thu Jul 04, 2019 12:54 pm
Lurked around Vancouver WA depot this week and scanned RR band for several hours. No NXDN modulation was evident. 935 and 936 ATACS and 220 PTC were being used.
PostPosted: Thu Jul 04, 2019 4:26 pm
When licensing it does not cost anything extra to add multiple modulations. Allot of techs do it trying to future proof and/or lead a customer a certain direction.
PostPosted: Thu Nov 14, 2019 10:15 pm
CP rail adding another NXDN site this one is on Mount Seymour . Much wider coverage than there 2 other rail yard sites . Right now using
160.74 lcn 7
161.52 lcn 8
160.2225 lcn 12
still doing testing
