It is currently Fri Mar 29, 2024 4:58 am
PostPosted: Thu Jul 28, 2016 8:00 pm
154.725 (97.4)- Inyo County Sheriff Dispatch
155.415 (136.5) Input to ICSO Dispatch
769.41875 ($DB1)- California Highway Patrol mobile extenders
153.875 (151.4)- Inyo County Fire Dispatch? Units returning in service here.
463.525 (151.4)- Some random road construction flaggers on Highway 14 in...Mojave?
460.225 (192.8)- Kern County Sheriff dispatch
153.785 (167.9)- Kern County Fire Dispatch?
154.905 (???)- Some random law enforcement agency, dispatch
154.860 (91.5 or 94.8)- Another LEA, this one may have been in Nevada- my notes sucked.
PostPosted: Thu Jul 28, 2016 8:01 pm
Add 170.100 that was scribbled on a napkin from a bar. Note says "Cops".
PostPosted: Sun Jul 31, 2016 10:50 am
That's the VHF vehicular repeater used by CHP. That's the frequency that the old "Bear Tracker" scanner used to listen to for activity, which meant a CHP unit was near by.
They are beginning to move to localized 700 MHz P-25 frequencies for the mobile extenders, this still shows up now and again.
- Chris
Chris Parris
Federal Wavelengths columnist
The Spectrum Monitor Magazine
chrisparris@thefedfiles.com
PostPosted: Sun Jul 31, 2016 10:51 am
Frequencies scribbled on napkins from a bar are always the best! :-)
- Chris
Chris Parris
PostPosted: Sun Jul 31, 2016 12:37 pm
- Chris
No, this sounded like a city PD or Sheriff's department. There was a dispatch on a DV in progress at an apartment somewhere, a few traffic stops and a BOLO notice from "Metro".
None of the "Station-xx" that CHP uses.
PostPosted: Sun Jul 31, 2016 2:49 pm
- Chris
Near the border of another state by chance?
Extender Frequencies
Ch. 01 - 154.9050 - 173.8 Car-to-Station
Ch. 02 - 154.9050 - 156.7/186.2 C-to-C
Ch. 03 - 154.9050 - No PL Direct
Ch. 04 - 154.9200 - CLEMARS
Ch. 05 - 156.0750 - CALCORD
Ch. 06 - 155.4750 - NLEMARS
Ch. 07 - 155.4450 - 192.8 Motors to Stat
Plumas County uses 155.445 in place of 154.905
http://fjallfoss.fcc.gov/General_Menu_Reports/engineering_search_out.cfm?service_select=%25&accessible=NO&state_select=CA&county_select=All&begin_freq=154.905&begin_freq_type=M&end_freq=&end_freq_type=M&polar=B&radio_ch0=P&lat_ddd=&lat_ddd_cfforminteger=Latitude+degrees+must+be+numeric.&lat_mm=&lat_mm_cfforminteger=Latitude+minutes+must+be+numeric.&lat_ss=&lat_ss_cfformnumeric=Latitude+Seconds+must+be+numeric.&ns_radio_ch1=N&lon_ddd=&lon_ddd_cfforminteger=Longitude+degrees+must+be+numeric.&lon_mm=&lon_mm_cfforminteger=Longitude+minutes+must+be+numeric.&lon_ss=&lon_SS_cfformnumeric=Longitude+seconds+must+be+numeric.&ew_radio_ch1=W&radius=&Radius_cfformnumeric=Radius+must+be+numeric.&distance_type=&lat_ddd2=&lat_mm2=&lat_ss2=&ns_radio_ch2=&lon_ddd2=&lon_mm2=&lon_ss2=&ew_radio_ch2=&soundex_select=&wild_select=on&begin_grant_date=&end_grant_date=&begin_expiration_date=&end_expiration_date=&sortstring=%2C+lic_name%2C+file_num&limit_select=4
PostPosted: Sun Jul 31, 2016 3:37 pm
Nowhere near Plumas County (at least until November). Probably those wily Nevadans...
PostPosted: Wed Sep 07, 2016 11:20 am
Culver City
461.4375 D115 (R?) Westfield Mall Target. Channel 1 (main ops). Repeated according to WQLA877
461.6375 D506 (R) Westfield Mall Housekeeping WQQS775
464.4750 Mall Security WQQS775
467.8750 (67.0) Probably Old Navy
LAX - Analog
All repeated unless noted
451.3125 D606 Unknown
Probably a shuttle service
453.375 (118.8) Los Angeles World Airports Maintanence KTU271
Maintenance calling dispatch. Toilets in the terminal; dispatch gave an incident number. Escalator restarts, another incident number. Moto radio unkey sound
460.525 (118.8) Los Angeles World Airports Police WZG297
Sounds like airport PD. Some TRBO interference. K9 unit. Adam unit, parking structure patrol. Lincoln, Mary units
461.4875 D612 Matrix Aviation Services Unconfirmed WQJY371
Airline gate ops
461.5625 D065 Unknown
Gate 27, the rest too unspecific. Gate 27 serves Korean Air, Hawaiian Airlines, JetBlue, Air Canada, Air New Zealand, and United and half of those are code shares.
463.5375 D132 Hyatt Regency/QuikPark Shuttle
Shuttle serves both since they're more or less interconnected
464.7625 D174 (S) Unknown
Bag ops? Mostly reading off numbers
469.0375 D612 Unknown
"2020CVI". Not sure if simplex or RI
469.1375 D631 Unknown
Not sure if simplex or RI. Nothing specific on the comms
LAX - MotoTRBO
460.65 Delta Airlines Cap+ WNYH314
DCC1 Cap+ Ch1/2. 10 chs total. TGs:
13 Cargo ramp
16 Towing a SkyWest plane to a gate that should open soon
18 Possibly gate ops
20 90 year old passenger at the gangway at gate 58. 58 used bay MANY airlines, but Delta most likely. Reusing tags at gate 57
21 "Full house, departing with ___"
25 "Hey Diego we found it"
29 Get some LD2s?
460.75 Delta Airlines Cap+ WRZ759
Weak TRBO from T3. Confirmed by license only
462.4625 Unknown
DCC7. Crappy decode. Slot 1 TG 705580 possibly bag ops. Slot 2 TG 705581 Nothing very specific; people calling base
463.4375 Jet Blue Unconfirmed WQIN396
DCC12 TG 16777215 (broadcast) on all comms. Bag belt ops. Probably Jet Blue or possibly WQKC873 - Elite Line Services California Inc.
463.5 Southwest Airlines Unconfirmed WQPS597
Cap+
463.7125 Southwest Airlines Unconfirmed WQPS597
DCC7 CapMax Ch3/4. Seen group 20
464.0875 Southwest Airlines Unconfirmed WQPS597
Cap+ (if SWA, probably CapMax)
464.6125 Virgin America WQHF786
(was PL 203.5 2013-05-03). DCC2 TG 684193 on both slots. Slot 1 = gate ops; Slot 2 = bag/ground/carousel ops. (B/D/E?)SL - bag ops place. RIDs 10x, 10xx, 50xx, 60xx.
Malibu - Pepperdine University
152.8700 D445 Shuttles
451.3500 D411 Unknown usage, probably facilities
461.5125 D031 (R?) Pepperdine Parking and/or Public Safety (gatehouses and parking enforcement)
462.4875 D723 (R?) Only licensed for mobiles on this freq; they're either very high powered or this is repeated. Not much to go on, somebody needed a flashlight
463.5250 (131.8) Unknown usage, probably facilities
464.4375 Someone doing a radio check with no response
464.9625 D311 Unknown usage, probably facilities
All of the above on KB84278
Malibu
457.6125 (71.9) McDonald's Drive Thru
Westchester - The Promenade at Howard Hughes
451.3250 Unknown usage. WQOD758 MotoTRBO DCC14 Slot 1 TG 503015 low 2 digit units calling base. RIDs 10xx
464.1625 Security. WPQD441 MotoTRBO DCC3 Slot 1 TG 201424 Sx and POx units advising S2 that various locations are code 4. 10xx RIDs. Locations such as __ parking lot, 6060 building, 6701 building. Channel 2 is the same TG on slot 2. Units are "ess" and not "Sam" or "Sierra"
467.9000 D043 Probaby Dave and Busters. WQXE830
Other
455.1125 (186.2) KMEX audio KPF893
PostPosted: Wed Sep 07, 2016 8:29 pm
Show off.
PostPosted: Wed Dec 14, 2016 11:13 pm
Pimp Daddy Radio
Hit a brotha up next time you're in town.
PostPosted: Thu Dec 29, 2016 6:32 am
Isn't LAX where there is like 5 channels just for that damm WallyPark and their never ending boats of shuttles?
PostPosted: Mon Jun 18, 2018 11:04 pm
Boats? Flotillas?
PostPosted: Tue Mar 03, 2020 5:40 pm
462.225 (D411) Courtyard- Pasadena
PostPosted: Tue May 05, 2020 11:11 pm
Boats? Flotillas?
Yes. And Gondolas!
PostPosted: Fri May 22, 2020 5:52 pm
461.650 (CC-8; TGID 104) Gold Base completely encrypted
