It is currently Sun Feb 18, 2018 12:57 am
 Post subject: CHP Command Vehicle Pic.
PostPosted: Sun Apr 06, 2014 1:22 pm
CHP command rig. Things that make you drool.
Duct Tape will not fix stupid. But it can sure muffle it.
PostPosted: Sun Apr 06, 2014 1:38 pm
What happens if it rains? :D
PostPosted: Sun Apr 06, 2014 1:44 pm
Theres a 3 foot circle drawn on the ground in front of her. Once 5 drops of rain land in the circle they pack up and go home! :D
Otherwise they use the same method that my aerostar vans do. You hope the door over your head stays up in the wind. :wink:
PostPosted: Sun May 04, 2014 3:47 pm
"Can you hear me"?
"Why isn't this thing working"?
PostPosted: Sun May 04, 2014 4:00 pm
Um, it's VHF lowband. It'll work.
PostPosted: Sun May 04, 2014 7:28 pm
Um, she's indexing. Sorta.
edit: The Mic. (for what's his name)
PostPosted: Sun May 04, 2014 7:37 pm
Looks like the guy on the left is sucking his thumb. :D
PostPosted: Sun May 04, 2014 8:09 pm
Yep, next she'll be babbling on the phone...
:lol:
PostPosted: Sun May 04, 2014 8:43 pm
:lol:
Finding that picture reminded me I had a lowband Maratrac in storage that Ive since pulled out and am re-installing. :D
My first thought was that he was contemplating hitting on her. 8)
PostPosted: Sun May 04, 2014 8:52 pm
Probably heard an interesting conversation and is eagerly awaiting her turn to talk. I can understand your confusion.
PostPosted: Sun May 04, 2014 9:22 pm
" :oops: :evil: :evil: :roll: :!: :!: :arrow: :idea: :x :oops: :chaingun: " Will you jerkoffs get off the air so I can order a donut and some Midol!"
"And what do you mean when you say I have to push the button when I talk?"
PostPosted: Sun May 04, 2014 9:51 pm
Eric???
PostPosted: Fri May 30, 2014 6:34 pm
Do I see Analog W9 Spectra Control Heads? :P
PostPosted: Sat May 31, 2014 5:19 pm
good catch! :D
I originally thought they were Maratrac's as the Spectra never came as a lowband model. The JPS Ratheon unit below the radios debuted at IWCE in 2009 if I have my JPS products correct.
Obviously interoperability would dictate the need for other bands. The PM1200 was not out yet and CDM only came as a 60 watt radio so Kenwoods were chosen. Even today with the PM1200 being a re-badged Vertex I wonder if the CHP would touch it.
PostPosted: Mon Jul 28, 2014 8:08 am
Primary (Vhf Lo Band) Radios will be set to operate in the 39 - 46 Mhz band. ( 42 Mhz input -- 39 mhz, 44 + 45 Mhz output / base ). Units will have radios to communicate on all bands - ( VHF Hi band, UHF 450-512 Mhz - Yes the extended UHF TV band, as well as 700 & 800 mhz bands ) In certain County areas -- ie San Diego County -- local CHP dispatch / operations may take place on the local Unified trunked radio system (700 + 800 Mhz P25) as well as low band -- or in place of low band.
