It is currently Sun Jul 22, 2018 6:08 am
PostPosted: Sat Dec 24, 2016 7:43 pm
DSD+ 2.29 New Features
The -dr and -dh command line options have been removed
DSDPLus.radios file loading speed has been increased
An eye pattern display has been added to the source audio window; right click to control
Yaesu Fusion voice decoding only (no link control data) has been added; -ff option added
Cap+ sites with no OTA site number should no longer display as site #1
Con+ OTA frequency file decoding has been added; if a site is broadcasting a frequency file,
DSD+ will decode it and write its contents to the console log; DSD+ will also write a text
block that can be copied directly to the DSDPlus.frequencies file
DSD+ now fully decodes more MotoTRBO LRRP messages
Decoding of some NXDN data frames has been added
Decoding of NEXEDGE AVL messages has been added; talkgroups that are used for data calls should
have their priorities set very high, i.e. in the 1 to 10 range; voice talkgroups should use
lower priorities (11 to 99); DSD+ will briefly interrupt voice calls to acquire AVL data;
use HIGH or HOLD priority on voice talkgroups that should not be preempted by AVL updates;
AVL data is written to DSDPlus.LRRP; use LRRP.exe to view
Error correction of P25 link control messages has been improved
Audio shaping filters have been added for all protocols; use 'S' to toggle filtering on/off;
use 'N' to toggle noise filtering (use 'n' for neighbor list control); use settings that
produce clearest eye patterns
FMPA 2.9
FMP24 2.14
The loading speed of frequency data files has been significantly increased
The spectrum window now displays license data as you hover the mouse pointer over the spectrum
I/Q processing latency reduced to handle NXDN AVL messages
LRRP 1.03
LRRP now remembers its window location, dimensions and text size;
left-drag in lower right corner to adjust window size;
right-click in lower right corner to adjust text size
